Radiator conversion
I have a one-pipe steam system. A new boiler was put in last year with extra capacity for adding an addition to the house, which is now under way. Are water system radiators easily converted for use in a steam system? Is it just a matter of converting the venting? Is there a minimum size pipe entry needed for steam? If I need to enlarge the pipe entry, is this difficult to do?
Many thanks in advance for any help you can give this novice.
