Hi-velocity AC & Fresh Air
RonM
Member Posts: 1
Trying to plan for a 2000 sq ft home with radiant floors throughout and I was told the best thing to do for air quality is to have something like an air to air heat exchanger. (I think the name is Lifebreath).
How would a system like this tie into a hi velocity AC system?
Would these systems have to be 2 separate air handling systems? Or could one duct system handle both frsh air and AC?
Ron McDaniels
Ron McDaniels
Hi Velocity & HRV
I think you need two seperate duct systems. The HRV fan would not generate the required static to move air throught the mini duct system. HRV uses conventional fan .1"WC static vs 1"WC. Contact HRV manufacturer to verify.0 -
The fresh air supply could be installed in the HV a/c return plen. Only the supply side is under high pressure.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
