Best Approach
Bill Riordan_2
Member Posts: 1
I looked at a job where a customer wants to heat a proposed finished basement. Radiant floor heat would be prefered.I was wondering if anyone could recommend the best way to lay the tubing on top of the existing concrete floor. Max floor height is 2 inches above existing floor height. Finished floor would be tile.I not certain of the proper insulation required or best type of underlayment for the floor tile. Any help would be appreciated.Thanks
radiant over existing concrete floor in basement
I would use something modular , easy to install , has thermo mass and is waterproof.0 -
Roth
Has an interesting looking aluminum skinned insulated panel out that seems as though it would be great for your application. You can probably find it on their web-site. Supposedly you can lay your tile underlayment right on top of it and proceed to tile as usual.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 993 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
