Steam Main Insulation
Chris NJ_2
Member Posts: 10
Yes, the main vent is about 10 feet past the last riser.
Question about pipe insulation. On a 1 pipe system (continous loop main) the distance between the last riser and the drop to the wet return is about 15 feet. Is it worthwhile to insulate all the way to the wet return drop or end the insulation 3 or 4 feet past the last riser?
IMHO I am thinking of insulating about 4 feet past the riser and leaving the rest open to (1) provide some heat to basement and (2) the steam reaching this part of the uninsulated main would condense rapidly thus creating a slight vaccuum to pull more steam through the main. Your thoughts?0 -
Is there
a main vent after the last riser takeoff?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
