Noel or Steve Levine ????? Scott Milne
ScottMP
Member Posts: 5,883
Friday afternoon are you guys out there. I need some tech advice on a flue damper
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Scott
What can I do for you
Mr Milne???? Call me 401-437-0557.0 -
Good to talk with you today, Scott
How did you make out with that oldie?
Noel0 -
Thanks so Much
Worked great Noel.
And Timmie thanks for the offer. I had a bad flue damper at 4:00 on Friday afternoon. I needed to by-pass it for the weekend and needed to know the color codes for the end switch.
Noel and crew came thru with shining colors.
Scott
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
