Most effecient temperature for radiant floor
Karen
Karen Member Posts: 2
I have a workshop with a radiant heated floor. I was setting the thermostat at 55 degrees but my radiant contractor suggested that I set the temperature at 60 degrees for the system to run more efficiently and save on propane. The floor is heating a 600 sq ft space with a 37,000 BTU propane DHW heater. He said the floor was having to heat up too much to give off heat with the setting at 55 degrees. I don't understand this. Would I not use less fuel running the system at a lower temp? The hot water heater was not short cycling at the 55 degree setting. How can I determine the most economical temp to run my floor at?
