New B&G pump
DanHolohan
Member, Moderator, Administrator Posts: 16,647
Bell & Gossett Introduces New Stainless Steel
Wet Rotor Circulator SSF-22
Morton Grove, IL December 19, 2002 Bell & Gossett has introduced its newest addition to their wet rotor family of circulators. The
SSF-22 is a stainless steel wet rotor circulator designed for domestic hot water recirculation systems in residential and light commercial applications.
The durable, stainless steel pump body casting makes it ideal for water recirculation systems. Available with a powerful 115/1/60 motor, the SSF-22 is rated for a maximum temperature of 230°F at 150 PSI maximum working pressure, exceeding most current code requirements.
The DuraGlide bearing system in the SSF-22 incorporates several components that work together to maintain consistent start-ups and trouble-free service. Double-Sintered carbon bearings, a ceramic shaft and generous clearances allow the circulator to resist calcium and chloride buildup.
The SSF-22 is backed by Bell & Gossetts three-year warranty and comes with industry standard flange-to-flange dimensions. Additional features of the SSF-22 include:
· Rugged pump body with high quality, stainless steel casting.
· DuraGlide bearing system assures whisper quiet operation.
· Powerful motor provides dependable start-ups, extending the operating life.
· Timer Kit and Aquastat in compliance with UL standards
· When installed in a recirculation system, the SSF provides the luxury of
instant hot water at the tap while preserving our natural resources.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone +1.847.966 3700; fax +1.847.966 9052; or visit www.bellgossett.com.
Retired and loving it.
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
