high efficiency boilers for apt bldgs?
ken_6
Member Posts: 33
love munchkins but have 2 weil 1386 boilers at 2.7 mil ibr
owner wants to replace with super high eff .getting $15,000
monthly bills
how about gas master?
any suggetions?
monthly bills
any suggetions?
high eff boiler
ken,
can you find a fulton the correct size they run up around 97%
chris smith
paradise porter maine0 -
Picture this a bank of 14 -199M Munckins
delivering 2.7 mil btu's. All tied in to a exhausto venting system so as to vent in to one common vent. Staged differentails. What a mines picture. We have 9 like this in our lab its a beautiful thing. Nothing like backup. We are working on the big boy and it will be out by years end the 399. 10 to 1 Well Can't win them all.
If you should need any thing e me0 -
Gasmaster only...
has about 5-10 boilers installed in the country as far as I know and they have enormous pressure drops through the heat exchangers.
Take a look a the Viessmann Vertomat. Fully condensing and modulating with efficiencies of 95% or higher depending on return water temps. Up to 3.3 million BTU/hr. They have been making this boiler for over twenty years with zero failures.
kf0 -
Have looked at baseloading?
I'd look at keeping one or both existing boilers and baseload the system with some high efficiency boilers. Calculate the typical winter day heating load and size the new boilers to meet this load. I bet this will only be about a 1/4 the peak design load because occupants help keep the building warm. This would save a bundle on the installed cost and provide a very quick payback of teh investment. Set up this way the old boiler(s) would only be used about 10 days a year under extreme conditions or maybe during warmup from nightime sethacks....they'd probably last forever.
Boilerpro0 -
We are
in the middle of suppling a school system with 27 Viessmann Vertomat boilers for 12 different schools. They are replacing existing old Kewanee's with 2,3, or 4 Vertomat boilers depending on load. We can stage, rotate, all boilers with on board Dekamatik controls. Fully condensing, fully modulating, no low limit, 316 titanium stabilized stainless steel (surgical grade). The two requirements for the school were low noise levels (they were used to the old powerburners going off like a rocket every few minutes) and high eff. The boilers are in their first season so it is a little early to pat ourselves on the back but so far the school system is over the rainbow. Viessmann was able to project a payback of 4 years on over 1,000,000 worth of boilers. That means that after the fourth year (if the caluclations are correct) they will see a 100,000 $$$ in savings annually. They can buy a lot of school supplies with the money saved!
Michael Bleier
Able Distributors
www.abledistributors.com
"The Supplier That Works With You"0 -
Hot water, right?
I believe you're interested in a hot water boiler. Am I correct? Have you ever looked at or considered a Patterson Kelly hot water boiler?0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
