Heat reflectors for steam radiators
A chilly consumer
Member Posts: 3
Does anyone know where I can buy the foil reflectors (or suitable substitute) to place behind my steam radiators. The old ones have deteriorated and the local stores (including Depot) don't carry them any longer. If you have them I will be glad to cover shipping.
I'm in Westchester Co., NY.
Thanks.
Thanks.
heat reflecters
find a sheet metal shop have them cut you some sheetmetal to size
A simple sustitute
You could just buy some foil faced hard board foam insulation and cut it too size for each radiator.
Boilerpro0 -
Foil works
great, any one can do it, but my grandfather allways had me using "coke tin". Nice and brite, will stay brite if kept warm and dry, cand be hemed, bent, and will stand by it's own self. Makes cool noises like thunder when you play with it too!Also great for cookie cutters and cake sheet, bread drawer liners, ect. good luck0 -
Foil Paper
In your case with built in convectors, your probably better off purchasing a roll of foil paper from a supply house in the area and replacing what you have there now, since there is not much room behind them to install fiberglass foil face insulation.
Hope this helps..........Ant
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
