combination steam/hot water system
Mark_4
Member Posts: 13
What is the best way to control the temperature of the water comming from a tube in shell heat exchanger. I was called to the job for circulator leakage & found the modulating valve controlling the steam had it's linkage (cam)missing& the valve stuck wide open.Then there is a three way valve which has been abandoned like a car in N.Y.C. all stripped apart. The system is only controlling commercial radiation to a few zones , no need for mixed water temps. Can I supply 180 -190* water from just the steam control valve or do I need the three way valve ? Suggestions? Mark
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
