pannel system
c-rex
Member Posts: 48
invited to do some near boiler piping to finish up a seven circuit pannel system that has the tube installed on top of the slab, beded in sand, and coverd with 5/8" OSB. the perimiter of the slab has beeen insulated, ten feet in from the out side walls, but the center was left un-insulated to force the heat to creep in. the system designer also has recomended a 180 degree water temp. I'm wondering, should I help these people, or go on vacation.
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
