american radiator boiler
[Deleted User]
Here are some numbers for you.
Boiler # Inside Length Net Water Approx Oil Input
715 15 " 545' 1.1 GPH
719 18 1/2" 655' 1.3 GPH
723 22 " 770' 1.5 GPH
727 25 1/2" 880' 1.7 GPH
731 29 " 990' 2.0 GPH
The oil input is approximate. You can reduce input w/ a modern flame retention burner and proper combustion chamber.
Just curious. Why continue use of a 50+ year old boiler?
Good luck.
Good luck.
looking for info on an "american radiator" boiler, model #7. specifically the recommended firing rate for #2 fuel oil. boiler has 6 sections.0 -
I have these specs
but they don't designate sections. They give dimensions, though. Interestingly, they rate firing for oil in pounds per hour burned (and at 19,700 BTUH per pound).
I'd be happy to fax the specs to you.Retired and loving it.0 -
American #7
Good luck.
American #7
The format is going to garble what I had lined up very neatly. I hope you can cybergeek it. Sometimes these things are a pain __ ___ ___.
Just curious. Why continue use of a 50+ year old boiler?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
