Loop Hot-Water Heating Digital Programmable Thermostat
John D
Member Posts: 1
Are there any Programmable Digital thermostats that work well with a Loop Hot-Water Heating system(radiant)from circa 1957? I tried a cheap Lux version (LX500-2 wire hookup,24volt). I turned down the heat to 66 degrees when I wasn't home and wanted it to pre heat the house to 71 right before I arrived home, however it took 6 hours to raise the temp and it still only rose to 70 degrees! It work fine with the old round thermostat so I started wondering if Digital thermostats aren't good for this type of system. Does anyone have any sugestions?
Thanks for you help,
John
John
radiant systems are not as responsive as other types of heat. the best thing you can do is allow the water to continually circulate and, modulate the temperature of the water in the radiant loop, in relation to the temperature outside. you will need a seasonal pump controller and a mixing valve with an outdoor sensor. depending on how your system is piped this could be quite an undertaking. there is a company called "stadler" that sells radiant systems but you must go through a contractor. you should have someone who is familliar with radiant look it what you have.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
