A new market for Taco (interesting stuff) - Dan H.
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,647
TACO INTRODUCES ITS PRO-FIT™ FAMILY OF REPLACEMENT PARTS
FOR BELL & GOSSETT AND ARMSTRONG PUMPS
To serve the needs of both contractors and wholesalers for quality replacement parts, Taco has introduced its new Pro-Fit™ family of replacement parts, specifically designed and built to fit both Bell & Gossett and Armstrong pumps.
The new Pro-Fit line includes a total of 37 high quality parts. These parts include motors, bearing assemblies, a universal seal kit, heavy duty couplers and impellers. All are guaranteed to fit all Bell & Gossett and Armstrong pumps with fractional HP motors up to 3/4HP.
“There’s a huge installation base of residential and light commercial B&G and Armstrong pumps out there that Taco intends to tap with our Pro-Fit line of replacement parts,” says Tom Lawrence, Taco’s senior vice president of sales and marketing.
“Pro-Fit parts are of the highest quality and durability, all American made. With the Pro-Fit line we can now offer installers and stocking wholesalers a consolidated and simplified family of parts. That means less parts to stock, and less parts to carry around,” says Lawrence.
Maintenance-Free Motors
Pro-Fit motors are supplied to Taco by Baldor and include 11 models ranging from 1/12HP up to 3/4HP. Their permanently lubricated, ball bearing construction make Pro-Fit replacement motors maintenance-free. All Pro-Fit motors come with rigid steel mounting cradles with resilient motor mounts for easy alignment of motor and pump shaft.
Heavy-Duty Bearing Assemblies
Five heavy-duty Pro-Fit bearing assemblies replace all Bell& Gossett and Armstrong seal/bearing assemblies, reducing the number of SKUs that wholesalers have to stock. For example, Pro-Fit model number BRG-B-100 replaces six different Bell & Gossett bearing assemblies. Universal bearing assemblies are bronze-fitted with S/S faceplates for use on open or closed systems. Their rugged die-cast aluminum construction ensures proper alignment with the motor shaft for longer bearing life.
Page 2
Replaceable Bearing Cartridge Kit
Pro-Fit bearing assemblies are designed with one universal replaceable bearing cartridge. This allows one cartridge kit to be used to service every Pro-Fit bearing assembly, simplifying parts inventory for contractors.
A Universal Seal Kit
Pro-Fit offers one universal seal kit to fit all models with ½” pump shaft. Ceramic and carbon surfaces are designed for extended wear and long life.
Heavy-Duty Couplers
Two Pro-Fit heavy duty coupler models eliminate the multiple Bell & Gossett and Armstrong coupler inventory. With reinforced eyelets, durable springs and rugged die cast construction for a long operational life, the Pro-Fit spring coupler fits up to 14 B&G and Armstrong pump models.
Durable Impellers
Ten Noryl® Pro-Fit impellers replace all Bell & Gossett and Armstrong pumps through 3/4HP models and are designed to match original performance curves. Pro-Fit impellers can be used for both closed or open systems, cast iron or bronze pumps, reducing parts inventory up to 50%.
Taco has a full series of informational literature available at wholesalers nationwide to introduce the Pro-Fit line of replacement parts. Contractors and wholesalers will appreciate the easy cross-reference charts that Taco provides showing individual Pro-Fit part numbers cross-referenced to both Bell & Gossett and Armstrong matched parts.
For more information on Pro-Fit replacement parts, call Taco at 401-942-8000
Retired and loving it.
