Gordon-Piatt Oil Burner manual
Alaska Joe
Member Posts: 37
I'm looking for a manual that shows the correct pressure setting for a fuel pump serving a Gordon-Piatt mod#R8-2-0-10 burner. Any info would be appreciated. Thanks
As applied to a Weil-Mclain 5-88 the pressure is 290Hi
100 lo using 2 2.75 Delavan80 B. It is 280/100 using2 3.5 delavan 70 B. But you probabaly do not have a W/M as the model would be WR 8-2-O. TRy "Oiltechtalk.com."0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
