Weil McLain GV Gold
cowie
Member Posts: 8
When piping 3"Z-Flex vent and 3"PVC air intake through a foundation wall (concrete) what can I use to seal around the piping? Will cement harm the stainless steel? I thought of cement or sillicone however the space is rather large for sillicone.
Any help or thoughts are appreciated.
Cowie
Cowie
mineral wool is a good coice for high heat applications0 -
Different companies
that make the vent pipe make a wall thimble for going through the wall. If it is Z Flex I have a catalog at my training center I can get you some info on Monday.0 -
the supplier
who sold you the boilers and/or stainless steel should carry wall thimble's for this application.0 -
You still need to seal
around the thimble to waterproof it through a side wall application. Silicone would work. Also tile supply stores have colored silicone selection and some with sand mixed in to blend with the concrete or mortar.
For sealing directly against the stainless I have used RTV silicone, same as the stuff used to seal the joints on some brands od AL-29. Automotive supply places have it in grey color, if the red doesn't fit your decor!
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
