heating 200,000 gal of water
jay_3
Member Posts: 22
I'm looking to maintain a 200,000 gal tank of storage water
at 45 degrees F. the tank is outside above ground and uninsulated. design temperature for our area is o degrees F.
Can anyone show me the calculation(s) to determine the
steam requirements? I have plant steam available.
wood tank?
Surface area ?
of exposed water = evaporation and heatloss due to temp diff
and surface area of tank - is the bottom exposed?
wood - R-1 for insulation and use standard heat loss calculation0 -
Student Problem?
Find the pounds/hour of condensate (based on the delivery pressure of the steam) required to raise 200,000 gallons of water in a 0° environment by one degree.
It's ALL on the web.0 -
This should help
Retired and loving it.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
