when to drain boiler???
jim_14
Member Posts: 271
is it better to drain from the LWCO when boiler is running or after its run and still hot??? Im talking when you drain it until it runs clear for maintenance purposes???
Follow the instructions carefully
The purpose of the flush is twofold. The first thing is to clear the mud in the control. The second reason is to verify that the low water cut off actually does stop the burner from running when the water level in the control drops.
The burner must be running so that you can tell if it stops when you drop the water level. Use the instructions that apply to your specific low water cut off.
Noel0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
