Radiant system design
Bruno
Member Posts: 1
I own a 65 year old frame house that currently has a gas cast iron boiler with radiators. I want to convert to a combination of plex (Floor Joist method) and baseboard rads. I want to heat three levels; basement 950 sqr. ft(baseboards), main level 950 sqr. ft (radiant floor heat) and the 2nd level 800 sqr ft.(base boards)
Boiler specs:
Weil Mclain
Model CGM-6
D.O.E H.T.G. Capacity 138,000 lb/hr
Min releif valve cap 138 lb/hr
Questions: 1. Can I use my existing boiler?
2. Can I use a cobination of pex and base rads?
3. Can you provide me with any design recomendations?
Boiler specs:
Weil Mclain
Model CGM-6
Bruno
Yes and yes. Who is doing the work. This should be done by an experienced radiant contractor. Then if it needs adjustment you have someone to call. IMHO0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
