Manifold question
chuck shaw
Member Posts: 584
I am looking at a job, where a homeowner installed his own RTI brand tubing. I do not know of a supply house that I deal with, that carries RTI. Does anyone know if either Watts or Wirsbo manifolds and connections work with RTI brand tubing? Has anyone tried this before?
thanks in advance
Chuck Shaw
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
thanks in advance
Chuck Shaw
I think
the Watts system will accept RTI. If you have a tee branch laying around, try putting the fittng into the tube.
Where did the HO get the RTI?
I hope it is RTI and not Radiantec.
Mark H
Try
contacting RTI for availability in your area. 800-784-0234. Actually any crimp that has the ASTM # should work. RTI has a unique crimp ring. I think it's called an Oditker (sp) clamp, named after the inventor. Often seen in the automotive industry. One tool fits all the different sizes, which is handy.
Any of the other copper crimp rings should fit, and work. Watts, Vanguard, Quest, Sioux Chief, etc. Same goes for the compression style fittings.
If it's Radiantech, you've got a problem. They use a unusual size tube and fitting.
hot rod
99% sure
That it is RTI. Homeowner said he had been dealing with a compnay out of Long Island, for design and tech information. He said he got the tubing at a local supply house, but can't remember the name, was going to have to look up canceled check. If that is the case, I should be able to get what I need.
Thanks for the information
Chuck Shaw
It will probably work.
Chuck,
If I remember correctly, I have used Wirsbo manifolds with RTI (C-Pex) and Roth. As long as the outer diameter is the same, it should work. RTI was (still?) using Danfoss manifolds which are very nice to work with. I have used a number of them with no issues. I say that about all Danfoss stuff though.
Warm Regards,
hb
"Expert in Silent Warmth"
888-UB-COMFY
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Wirsbo
I love Wirsbo,but I wouldn't mix Wirsbo products with any other brand. Just my two cents. Bill0 -
wirsbo
i used wirsbo manifolds with embassy pipe, with no problems. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
RTI
I have used RTI tubing w/ other manf. fittings and manifolds, NO PROBLEMS. They have the BEST crimp ring out there. One crimper for all size rings, easy assy. & disassy.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
