Air Purge
George_5
Member Posts: 5
Air Purge
There are no valves to isolate a wing of our building. I want to put ball valves on the supply and return with boiler cocks on the wing side to get rid of the air. Does it matter if I open the supply and keep the return closed or if I open the return and keep the supply closed?0 -
purging
Yes, if you have a check vale .best to keep same flow, and you won't have to worry about it.0 -
Frank, Thanks. I thought I should do it that way. My buddy said it didn't matter. Now I have a reason.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
