too much air in hot water system
marcmm
Member Posts: 3
yes, but I probably will not get the photo on until tomorrow
I have a 105 year old house that has a 2 pipe hot water system with a big old pig of a boiler from the 1930's (probably). it was converted from a gravity fed system to a pump system, possibly at that time. the system seemed to work fine, but last year I came home from work one cold january day and found that the expansion tank had broken loose, and fallen from the ceiling ( don't know how that copper strapping tape and 1" roofing nails held a 35 gallon tank all those years). It broke the fresh water supply inlet pipe off of the tank, and the pipe that went into the top rear of the boiler also. The company I hired to fix it did not reattach a supply to the tank as before, and the only connection to the tank is from the top rear of the boiler. Since then I have had problems with air in the two tallest radiators of my top floor, they rarely have any heat coming out of them, and I bleed them constantly, I drained the expansion tank, but it is my understanding that the tank is supposed to be refilled to about 1/2 full. is this refilling necessary in a non gravity system? also, the fresh water supply is piped to the pressure reducer but they capped off the feed that came off the pipe before the reducer and went to the expansion tank. I hope I've descibed this problem adequately, and can try to answer any questions that wolud clarify the issue
thanks; Marc
Sounds solve-able!
Can you take a photo of that ex tank connections and post it ?
photos attached
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
