steam problem
ed wallace
Member Posts: 1,613
worked on 2 pipe steam system 2 weeks ago rad was not working pulled rad replaced the valves supply 1in. return 3/4 in. valves were good but had to cut them to remove rad while rad was removed turned on heat pipe was making panting sounds eventually steam forced condensate out of pipe and steam came out put rad back in place now rad only haets about 1/2 way across my thoughts are that the pipe is sageing in the ceiling do you guys think this idea might hold water (pun intended)
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=256&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
I think you've got it
try re-pitching the pipe.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
steam problem
thanks steamhead that sort of confirms my belief its great to get info from others who have dealt with this sort of problem before have a great christmas
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
