Need White Rodgers tech number....Boilerpro
Boilerpro
Member Posts: 410
Have several old 1F-97-1 thermostats with no intructions on how to adjust heating anticipator. Nothing on their website that I could find....tried newer instructions, didn't work, called the number I had 800-876-8324, not in service, called 314-577-1300 long distance, put on hold for 30 minutes, then their workday ended and a recording told me to call back another time....that really topped the cake. Do they have an 800 number, so the long hold will go on thier bill, not mine? Or if you have the needed info please E-mail. Thanks folks!
Boilerpro
Boilerpro
1F97 t-stats
I am checking my locations to see if I have something...I will keep you posted.
Michael Bleier
Able Distributors
"The Supplier Who Works With You"
Chicago
Evanston
McHenry
www.abledistributors.com
Give this a shot
http://www.whiterodgers.com/pdfs/instructions/1f90/0037_5100_A.pdf
On the white rodgers web page you can go to technical and they have all pdf's for old stats. If you have any problems you can call me at 847-417-0060 or I can print this out and fax it to you.
Michael
Able Distributors
Heat antisipator.
Do you know about the clamp on amprobe meter method. If this is a low voltage t-stat.This will do it for you.Contact me if you need the info..0 -
These are electronic stats...
on a zoned hot water system with both cast iron baseboard and convectors. I have amperage ratings from the relays, just need to find out how to access and change the thermostat settings. Thanks!
Boilerpro0 -
I have placed
a call into my WR rep...I hope to hear back from him today. I also found another number for WR (888)-725-9797. I have been on hold with them for 10 minutes as I type this...You are not out there alone!
Michael Bleier
Able Distributors0 -
Mike's got me in touch ....
with the people "in the know" (or least know where to look). Thanks to Mike and all those that responded.
Boilerpro0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
