sizing by orifice
bottomheater
Member Posts: 8
anybody have btu/hr data/orifice size? my only clue short of a room to room heat loss calc is a 7/32" orifice in an Economite in a J0T4
Fun ?
Looked up the bit # right between #2 & #3 size orifice drill bits. So at 3.5 inches of nat gas @ specific gravity of .60 A #2 would give you, 149.55 cu ft per hour, and a #3 would give you 139.91 cu ft per hour. Hope this helps bigugh OH > @ 3.5 inches of gas pressure0 -
orifice
thanks from the bottom of...0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
