Buderus Radiant Panels
Ray M_2
Member Posts: 64
I am getting rid of my hot air system.I am concidering the panels made by buderus for each room.Any pros or cons?
Buderus Panel rads
I can't think of one reason not to do as you plan.
With the thermostatic valves on each panel you get the ultimate in comfort control.
Go for it!!!
Mark H
Thanks Mark
I will use the angled diverter fittings with pex tubing for a one pipe loop.I will have 3 zones using outdoor reset and a indirect heater for domestic h20.0 -
It
doesn't get any better than that!!
Merry Christmas!!
Mark H
Ray ,
Welcome to the real world ! I totally agree with Mr. Hunt , you're getting the most comfotable heat available . Now ,if I may suggest the Buderus control to go along with the radiators , you will also have a most fuel efficient system . Good choice . Chris.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
