Wireless Thermostat?? Who makes them?
JR
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=96&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Tom Anderson
    Tom Anderson Member Posts: 40
    Danfoss, but Beware
    Danfoss. For 24 volt ac applications, the Danfoss TP-75 RF thermostat. You also need a receiver... they are available in either one, two or three zone capabilities Danfoss RX-1 or RX-2 or RX-3, respectively, per number of zones.
    Danfoss also makes a 24 vlt DC line, intended for radiant system zones, I am told.
    I had one installed several weeks ago in my home with baseboard hot water heating, ten zones with two position zone valves. I'll be posting a report of my experiences to date on this web site soon. It is working ok, but there are some quirks......
    However, *DO NOT* install the receiver according to the directions furnished with the receiver......... you WILL fry the unit, according to Danfoss. Call Danfoss before installing.
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Wireless stats
    Hi, John! Honeywell offers the T8665A1002, and a choice of either the W8665A1009 (ones stage heat/cool, 1 zone) or the W8665E1000 (1-3 stages heat,1-2 stages cool, conventional or heat pump, up to 3 zones. The stat can be anywhere within 200' of the receiver. Available from any Honeywell distributor. BTW...receiver wires up to the equipment like any stat. Go to http://hbctechlit.honeywell.com for a spec sheet & wiring diagram.
  • Brian
    Brian Member Posts: 285
    Wireless Stats
    Wirsbo has a wireless system called "Genius"
    Good Luck
    Brian
  • X-10
    I think X-10 makes one. Try X-10.com
