Resistor on Taco Zone Valve
John G. Merritt
Member Posts: 140
Hey fellas!
Why would a Resistor be installed on a Taco Zone Valve Between #1 Terminals? Had a clock thermostat on that zone. I was told it prevents feedback. How?
What feedback? I don"t understand this.
John
John
resister on zone valve
the resister allowes a complete circuit to bypass the zonevalve that cycles on and off. The current is needed to run the clock0 -
Still do not understand it!
Sorry, but I still do not understand the resistor being installed between 1 & 2 on the Taco Zone Valve!
I don't understand the feed back thing.
Sometimes I just don't get it. Need a clearer explanation.
John0 -
resistor
The resistor was installed to benefit the electronics of the t'stat. The thermostat has no batteries, so it needs to "steal" some current from the operating circuit, only a volt or so and very low amperage. So, it bypasses the switch that sends full power to open the valve and gets what it needs, and sends the rest down through the heat coil of that zone valve. This works fine until there is a call for heat and that taco valve opens. When the valve gets near full open, it interrupts current by opening a switch, so the heater coil doesn't overheat. Now the electronics have no circuit, so the thermostat goes into power-failure, shut down mode which has a capacitor to supply juice to maintain memory, but not operate other functions. The valve closes and restores power and after sulking for a while, the t'stat operates again. The valve opens, breaks the contact, and the t'stat shuts down again.
Etc.
The resistor gives current a path to go when that switch is open. It draws a couple of watts continuously, even when no heat is required.
Of course, the simple solution is to either use a battery powered thermostat (immune to power surges also), or another type of zone valve that doesn't interrupt current.
This little lesson cost me a number of hours of call-backs a number of years ago.
Bill0 -
Think I've got it!
Thanks Buss, Bill.
I think I've got it now.
John0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
