BOILER HOT WATER OUTPUT
john t colao
Member Posts: 6
I FIND THE HOT WATER FROM BOILER TO HEAT BASEBOARD IS NOT HOT ENOUGH.ALTHOUGH MY ACQUASTAT IS SET FOR 160 DEGREES.IT SEEMS ITS NOT EVEN CLOSE TO THAT.
QUESTION WHERE DO I LOOK FOR POSSIBLE PROBLEM OR PROBLEMS?
what does the
temp gauge say? Don't rely on the aquastat dial. the are terribly inaccurate. kpc0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
