Gasket
George Berkeley
Member Posts: 40
In the wet return of a single pipe steam system I have an 8 bolt flange fitting that has started to drip after 80 some odd years of use. I tried to evenly snug the nuts but that only increased the drip.
My local plumbing supply did not have a gasket that looked to fit so they gave me a sheet of red rubber to make a gasket.
My question is--do I need to use a gasket sealer or treatment on this fitting and gasket? And if so, does the treatment need to be steam rated?
You might be better off
going with a fiber gasket instead of rubber; rubber will harden, become brittle and crack at those temperatures.
As far as a sealant, I'd use some Blue Magic or Rectorseal and dope up both sides of the gasket before putting it all together.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
