air intake
billygoat22
Member Posts: 124
We installed a new boiler this week in a small shed. The old boiler was out in the open air-you could feel heat pouring out when it was idle. I cut in combustion air intakes in the wall of the shed for the new burnham boiler. I recall that you could run a 4" pipe to the burner for air instead of the louvers. If this is a confined space and air is supplied through the pipe, how can the draft regulator work properly? thanks for the help and great site.
- 86.6K THE MAIN WALL
- 54 Biomass
- 97 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 930 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
