Dog gone Wirsbo
hr
Member Posts: 6,106
has wished and wished for radiant floors all her life. Nobodys taking this pex from the jobsite.
Wish came true today :) 2500 square feet of gyp/ radiant went into her masters home today.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Baseboard
This might be a job to use that urine proof baseboard in the dog house.0 -
Baseboard
Is this your big
trip to Ar-Kansas?
One pipe steam system changes.
I'm contemplating making some changes to a one pipe steam system that I recently made near boiler piping repairs on. I plan on replacing all of the radiator vents with new Hoffman #40's. I was also going to replace the main line vents with Hoffman #4A (Selected because of limitations between the floor and the nipple on the dry return). The current system is outfitted with a mix - match of vents.
Am I headed in the right direction????
Also, I wanted to set the system pressure to 1/2 psi cut - in and 1 1/2 to 2 psi cut - out. Any recommendations as to what kind of gage I could use to set the pressuretrol? The current boiler gage is stuck at 5 psi. I purchased a new
0 to 30 psi gage to install later this week, but it doesn't look like it's going to be suitable for an accurate setting.
Thanks,
Harry Kirsch kirschhvac@zoominternet.net0 -
H.R.
I guess we know who rules that roost ! Looks like a real killer , be carful doing this one .(she might follow you and leave paw prints in the gypcrete or maybe even show you where the silverware is if your not careful )
Chris0
- 86.5K THE MAIN WALL
- 54 Biomass
- 97 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 930 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
