ph level of antifreeze system
![[Deleted User]](https://secure.gravatar.com/avatar/f02ac9f13afeb854bd494bae389e03ef/?default=https%3A%2F%2Fvanillicon.com%2Fc65330905255a4e9620dec6784df2642_200.png&rating=g&size=200)
[Deleted User]
for the fliud in a propelyne glycol added radiant system?i think i butchered the spelling of that.
Close enough
Dow suggest 8.0-10.0 New Dowfrost HD properly blended with good water at 50% will read 9.0-10.7 A ph tester or narrow range ph paper can be used to test.
Some manufactures recommend replacing the fluid if it falls below 7 ph. Personally if it hasn't been "cooked" (you'll know by the smell and color!) you can buy a boost product to bring it back up.
In the 6's or lower I would definitely flush, clean, and replace the fluid.
The ph is the indicator for the condition of the inhibitors, watch it closely. Yearly if possible on residential systems.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
