Steam Radiators
Sherri
Member Posts: 1
We have steam radiators in a rental unit and want to put something behind the radiator to reflect the heat back into the room.
Do you know if something like this exists and where you can get it?
Thanks!
herri
Thanks!
herri
Click on \"Find a Contractor\"
on the pipe on the left, and ask one fo them about some of the reflective insulation that is avalible. 1/4" thick plastic foam with Mylar on one side . good luck0
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 40 Industry Classes
