HIGRADE BOILER #24-10
john t colao
Member Posts: 6
WOULD LIKE TO OBTAIN INFORMATION ON A HIGRADE BOILER #24-10-----WHICH WAS ORIGINALLY A COAL FIRED STEAM BOILER INSTALLED IN 1905,EITHER THE CAPACITY OF THE UNIT OR THE MANUFACTURER WHERE I CAN ASCERTAIN SAME.
According to the Hydronic Rating Handbok
the Higrade was made by Thatcher. They don't show that model number though, and I believe Thatcher is long gone.
Keep in mind however- many old steam boilers were oversized so they could hold more fuel on the grate.... this meant the owner didn't have to shovel coal more than once or twice a day.
If you want to replace that old boiler, it's far better to measure up all the radiation in the building and use this figure to select the right size boiler. Get a copy of Dan's "E.D.R." book for radiator sizing charts- I believe there are some Thatchers in there. Also a copy of "The Lost Art of Steam Heating" for an in-depth look at the system you're working with.
If you come across something that isn't in the book, take a picture and post it here. We can probably identify it.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
