Expansion tank
Bruce
Member Posts: 27
Is there any diferance in an expansion tank and a pressure tank used on a water system.Can one be used for the other?Thanks Bruce
See the following
http://www.heatinghelp.com/heating_qa.cfm
has a lot of information and discusses tanks on hot water systems.
-cf0 -
water logged expantion tank
I think that my expantion tank is water logged. How much air should be in the tank. Also when I leave my main water supply turned on the pop-off valve or safety valve on top of my furnace drips. Anyone have any info to help me out. Thank you, Denny0 -
Expansion tank
What is the system pressure? Your tank pressure should be the same as your system. Make sure the tank does not have boiler pressure on it when checking. Also make sure bladder in tank is OK. Good Luck!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
