Low water cut off/feeder cuts, but will not feed
Ed_4
Member Posts: 3
Anyone have any suggestions. I have a McDonnell Miller 247-2 combination low water cut-off and feeder. The feeder is about 3 years old. It cuts off, but will not feed. I cleaned the strainer and tested it manually, but it still won't feed. Where do I go from here?
Pull the strainer screen out
again, and open the water valve to it to see if the problem is before the screen. If you can flow water through the strainer body, the problem is in the LWCO itself, or beyond. The linkages or the float itself may have a problem. I bet something is plugged in the waterways of the feeder, though.
Noel0 -
Replace
the SA47/101/102 Valve and strainer assy.ED0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
