steam pipes
ed wallace
Member Posts: 1,613
if its heating without banging or extra nioses leave it alone copper on supply side of steam systems are not a good idea
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=256&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
steam heat pipes
2 Fold 1st I have a single pipe steam system but in the basement the pipes seem to split (cold water return my guess) but I have been in other houses with single pipe and did not see the same style system. Can I remove this style without issues? 2nd the pipe is cast iron I have seen cooper used instead what do you think of changing over?
Thanks for the time0 -
\"Pipes Split\"
If you're referring to the end of the steam main where the pipe drops and then returns to the boiler, you're right- this is how the condensate gets back to the boiler to be re-heated.
While it is possible to pipe a one-pipe system without this return line, doing so would involve re-piping the steam mains also. This would be a very big job.
It may be possible to re-route the return line if needed. A good steam man will know how to do this and maintain the system's proper operation. Go to the Find a Contractor page of this site to locate one near you.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
