noisy fhw system
G.K.
Member Posts: 4
I installed a 2 zone fhw complete system about 10 years ago. Suddenly it is very noisy (air) and I have purged several times to no avail. I want to install a spirovent,however it is a Weil McLain GV3 (which has a built in bypass) and I am not sure where the proper placement of the spirovent is. HELP?
questions
Did you pump away?
I usually place the air elimination above the diaphram tank before the suction side of the primary circulator.
B&G makes what they call a heating module, they have alot of info on it. Dan's book is great too.
Velocity noise is a different matter though. Zoning with circulators can fix that.
the
Spirovent should be on the "secondary" loop piping per W/M drawing. You have the 1" loop off the boiler going to closely spaced T's usually upsized there for the required load flow. In the direction of flow the Spiro comes first, w/ feeder and extrol hanging off the bottom. Zone take-off's come next. This is a GV-6 w/ a TR80 indirect, a 10 ton hydro-air handler, and a small Modine heater for the loading area. It's installed in a chocolate factory.
Noise in electric heating system
I am just a lay person, living in an apartment in New York. It has a baseboard heating system with copper pipes.
When the weather gets really cold, usually 3 am and on until mid-morning, the pipes make a very loud hum and vibrate so that the whole floor shakes.
I have complained to the landlord, but to no avail.
It is a new building, and the boiler was working fine, and quietly, all of last winter.
Also, there have been successive days of no heat, so I wonder if the boiler is defective or needs adjustments or what??0 -
I did not pump away because the circulator on this boiler is connected to a built in mixing valve inside the boiler jacket. Wm states in the manual not to move the circulator so pumping away as I always do is not physically possible. There is only one pump as I used 2 zone valves to zone with.0 -
Taylor,
you will get better response to your question if you hit "New Thread" and state your problem.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
