air separator
Eric
Member Posts: 95
Primary/secondary pumping away with secondary baseboard loop and secondary radiant loop.
With cooler temps in radiant loop is that the best location for air seperator/rolairtrol on suction of radiant pumps? or go with 2 smaller one on each secondary loop?
1,000,000 Btu's two 500,000 boilers.
air separator
If you are pumping away on the primary loop, I like the air separator right there, above the diaphram tank on the suction side of the primary pump coming right out of the boiler.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
