System short cycles until system is hot
dan b
Member Posts: 4
OK, sorry for my ignorance. My steam boiler turns on and off until the system is hot, and then it runs continuously and normally. Any solutions? Thanks, Dan
check pressure control
The pressure control is not adjusted properly. You may want a service man to do it if you are not familiar with it. What is it set at now. Read carefully in lb / sq Inch to tenth decimal point. Get back with info www.exqheat.com0 -
pressure setting
John, Thanks for the reply! The "cut in" setting is 1.75 lbs/in, and the "cut out" is set at 2. What do you think? I wondered if part of the problem wasn't also that I need more air vents, since the ones that I have hiss pretty loud and I read that hissing is a good sign you need more of them. Thanks, Dan0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
