Barometrics versus draft hoods
Jim Davis
Member Posts: 305
Timmie, I missed your converstion on barometrics and drafthoods. Your posting on 1-17-03 is in response to some question that was posed, but it did not appear with your answer. It was once told to me by a high authority that the most dangerous device ever invented was a drafthood and the sooner they are obsoleted they better. I supervised the Field Report on Barometric Modifications on Drafthood appliances with a top AGA engineer, Field Controls and my students. The report states that in all cases barometrics made equipment safer than their original drafthoods. I always tell people check with their local lawyer to see who has and accepts ultimate liability for unsafe operation. But unless someone has proper training and proper test equipment they shouldn't make modifications. If fact they should not be allowed in peoples houses!
1
I think I saved it
I will kick it back up for you.0 -
Jim if you click
search and then type in Draft Hoods and my name you will get all my comments on the subject of Draft Hoods.0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
