RFH with UniBox-Paul P
Paul Pollets
Member Posts: 3,661
Oventrop makes a device called the "Unibox" which allows you to take off a radiant floor heating zone from radiator mains. No additonal piping, pumps or mixing valves are required. The box has a built in TRV and a limiter to set max. water temps through the loop(s). If more than 1 loop is required, a manifold is installed. Circuit BTU design not to exceed 13-15K. The device can be obtained from Chris Rorke at Blueline Supply in Jackson Hole,WY.(307) 733-3953.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
The Master Bath uses floor and wall RFH elements
The Master Bath using the Unibox is heated with Wirsbo Quick Track, wall warming using transfer plates, and mudsets under the shower, bench seats and at the bath entry. Notice the Entry Ramp mudset is comes directly out of the QT panel. The Unibox limiter is set at 115 degrees. In this case, we used a 3/8" loop for the wall warming and bench seats, 5/16" tubing for the QT and entry mudset
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 883 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 40 Industry Classes
