Oil tank shut off
Art Pittaway
Member Posts: 230
on commercial building with 1" line between bulk tank and boiler room feed tank. The customer has had troubles with solonoid valves leaking through and wants to go to a ball valve with actuator. #1 fuel oil in the tank has "debris" in it and they are looking into some type of strainer. Has anyone come across an application like this and what did you use.
Thanks.
Thanks.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
