Indirect Water Heater question
[Deleted User]
If I install an indirect water heater on a hydronic boiler should I use the tankless coil and pipe it to that or pipe it in like another zone of baseboard.Also for a typical house what size so diswasher and shower can run at once any recommended brand names? thanks
Also is this the most efficient way rather than a seperate oil or gas water heater?thanks again0 -
indirect
pipe it as a separate heating zone pipeing it into the tankless coil would be inefficint unless it is a storage tank
I agree with Ed. Pipe it seperate as a zone dont forget a checkvalve.If I think about eff. I think indirect is a good way but it depends also on your boiler your are using. I always consider a tankless water heater, like Takagie, Bosch,but this depends how huge the house is or better how far away are the bathrooms etc.
Good luck,
Mario0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
