Fusion Hydronics (hr)
hr
Member Posts: 6,106
This system incorporates a Superstore buffer tank. The buffer aquastat will call the boiler on and run a 140- 180 (40 degree delts T) maybe more :) Grundfos Super Brute 15-58 check pumps keeping everything going the right direction when the DHW priortizes via the Crown intergral circuit board.
A post purge relay will suck the BTUs out of the boiler after a call is complete, and shove them into the buffer tank.
If RB would stop shooting and start soldering I would have the correct 5 zone ZCP with 4 way mix and reset control that runs off the buffer tank, for this 5 zone gypcrete job.
The scaffold allows my to "mock up" the job room and allows easy roll around "prefabbing" I'll pressure test and run the whole package before I haul it to the job.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Ya know.........
The hydronic art is limited only by a guys imagination. As yours must be running at warp factor 7 all the time Hot Rod.
Nice, REAL Nice!0 -
> moreGrundfos Super Brute 15-58 check pumps
> circuit board.
> tank.
> job.
> hot rod
> _A
> 144&Step=30"_To Learn More About This Contractor,
> Contractor"_/A_
mega short
Make sure the guy that sized the Mega didn't get his gal/minute and gal/hours recovery mixed up. Showed a friend how to add a brazed plate so the HO could fill his hot tub. The specs I read on the Mega were not to great for recovery time. Nice place to work, nothing worse than doing it on the floor, and I'm to old for that.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
