Radiator-Wall spacing & Paint Type
Nobby
Member Posts: 20
Thanks for the input.
Awsome Radiator!
Awsome Radiator!
I am currently refitting large tube cast iron radiators on a hot water system and was curious as to the ideal spacing from wall to radiator? The figure 2 1/2" springs to mind.
Also anyone got a favoutite primer paint product suggestion for them that they use?
cheers
Nobby0 -
As long as you are not putting enclosures. Norby......
around them, it won't be too critical...an inch or two away from wall is fine......I use Rustoleum Mettalic heat grade spray paint....primes and colors in one shot...stay with either copper color, silver, or bronze....others colors will inhibit the heat too much. good luck Mad Dog
I believe Dan H says 2 1/2 inches
in his books... the old timers figured this out. RAD rad!
Boilerpro0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
