Radiant track ?????
Bigheadtodd
Member Posts: 20
Were can I go to get the latest and greatest information regarding transfer plates. Performance, install guide etc?
The question I have now is, when useing plates under sub floor, how should the insulation be placed, right up against the plates, or 1 inch air gap or???? foil back or???
thanks in advance
thanks in advance
You
must leave a 1-2" air gap between the plate and the insulation. As far as which plates to use, I use RTI's 3/8" Radiant Track and you will hear alot of people tell you that they have a problem with the tubing falling out of the plate. I have yet to run into a job here in my area in which I have had this problem but I'm not saying it probably doesn't happen. This plate is by far better than those flimsey thin alum plates and will also perform much better. Now, the reason I use these plates over Wirsbo's (which is the same exact extruded plate) is that they are about $1.50 cheaper per plate through RTI.0 -
Install info
Todd-
You can download our Design and Installation guide from our website on the Radiant-Traks www.rtisystems.com
or a condensed version attached.
Dave H.Dave H0 -
Radiant Trak installation
guide is available at our website www.rtisystems.com for the full guide or attached is a condensed version.
Dave H.Dave H0 -
Warm Regards,
heatboy
"Expert in Silent Warmth"
610.250.9885
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 78 Chimneys & Flues
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 377 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
