Question: Anticipator setting For W.R. 1F90 series
Boilerpro
Member Posts: 410
Was wondering what the numbers (range from 4 to 40) mean when setting the anicipator on these stats. Also some suggestions for initial settings on the following.... 5 zone church, most of the time in setback, 4 zones cast iron baseboard, one convector (large open sancuary. The boilers are 3 WM HE's series 3 (low water content) and cold start off the zones pump relays auxilary contacts. Instructions say a miminum setting of 15 is recommended for hot water systems. Thanks for the help.
Boilerpro
Boilerpro
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
