Electro Zone Zone Valves
Bill G
Member Posts: 8
I came across a system with 2 Electro Zone zone valves. The valves were wired to an Electro Zone relay. The relay not only feeds the TT signal to the aquastat, but it also feeds line voltage to the aquastat. That being said, I am looking for any info on Electro-Zone Valves and relays. Theses valves seem to be causing a regular short cycle. This is evident due to the fact that the closure of the valve cuts all power to the boiler. Help!!
Auto Mag used to make replacement parts for electro zone systems, but I'm not sure if they still do. Call them at 717-383-24280
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
